exactly when did the compression ratio of the 325 change?
orangecurry
Post Wed Sep 27, 2006 9:38 am
I know it was part of the face-lift, but is there an engine number for pre- and post- or a manufacturing date for the change so everyone can be sure?
ta
(I know this is similar to 'what engine do I have', but I thought if I put the question in the title I'd get more readers :D )
mrLEE30
Post Wed Sep 27, 2006 3:44 pm
judging by the reams of replies you can see it clearly worked :poke:
and my answer.... nee idea!
mrlee
orangecurry
Post Wed Sep 27, 2006 4:14 pm
are you startin'?
right then fishface, how do you know how many readers I've had?
as people don't need to even open the thread to see the question?
eh?
eh?
just because no-one seems to know the answer...
right I'm coming round your gaff right now; what's your address?
Ant
Retired Team Member
Retired Team Member
Post Wed Sep 27, 2006 6:11 pm
september 1987 for changeover, the saloon body was facelifted and the entire range given the lower CR and motronic management.
the engine CR change applies to all factory cabs produced after that date too.
orangecurry
Post Wed Sep 27, 2006 9:31 pm
thanks Ant :D
gooner1
Out humping Reindeer
Ant, humour me mate pretty clueless with engines but are the early higher CR engines better suited to either the 2.7 conversion or the turbo route or does it make no difference.
Ant
Retired Team Member
Retired Team Member
Post Wed Sep 27, 2006 11:19 pm
The early euro 9.75:1 engine will make a CR of 10.53 with the required block decking and material removed from the skirt to clear the crank ( check !!!! ) its a little high with the fuel of today, certainly require super U/L minimum or timing with a lot of retard, and lower power as a result
the 8.8:1 gives 9.5:1 with the 2.7, more realistic, but argueably easier to live with, and still potent
both CR are way to high to really FI with more than 7.5 psi (imho) CR in the 7.5:1 will have a much higher boost threshold, and ultimately more power, but will need the full monty big turbo, wasted spark and MS( or similar ) to get there, so major Ԛ£Ã”šÃ‚£ investment
I have said from the outset, anyone can go FI for 1.5K, and achieve decent results(240hp ish ), but once the bug bites, and it will, you'll be pulling another Ԛ£4K out , and smiling while you hand it over to your tuner of choice/ parts supplier :lol:
mrLEE30
Post Thu Sep 28, 2006 5:44 am
villa 23, gate 343, road 53, Budaiya 553 Kingdom of Bahrain
And i am ready for ya!!!
(but let me know what time your flight lands and i will send a driver to pick you up winkeye )
mrlee
orangecurry
Post Thu Sep 28, 2006 8:55 am
I'm on my way to the airport :x
mrLEE30
Post Thu Sep 28, 2006 9:01 am
so is my driver (he is hezbullah and will be in a red cabby, gun safely tucked away thanks to zone advice!!) :guns: :shoot1: :shoot2:
orangecurry
Post Thu Sep 28, 2006 9:29 am
DOH - I should have kept my mouth shut on 'weapon etiquette in the modern vehicle'
I'll be bringing the ultimate concealed weapon
