Lower control arms...
Matt_T
Post Sat Sep 16, 2006 5:07 pm
How are you meant to remove the inner balljoint? :?
Post Sat Sep 16, 2006 5:46 pm
You're not really, but they press out. Or grind the bottom off, knock the ball and pin out, and saw through the side of the bit that's left.
Matt_T
Post Sat Sep 16, 2006 7:37 pm
Sorry i meant remove the control arm from the subframe, managed to get the nearside off with a socket and breaker but looks like the offside will need a 22mm spanner.
Any tips on removing the bush from the 'lollipop'?
Chris-W
Post Sat Sep 16, 2006 7:56 pm
Very long extension bar down from the top of the engine compartment to undo the nut on the upper ball-joint.
You can saw through the metal sleeve at the outside of the bush to remove it from the lollipop.
Post Sat Sep 16, 2006 9:19 pm
Half inch drive "wobble" extensions are the tools for this job :wink:
Matt_T
Post Sun Sep 17, 2006 10:18 am
Chris-W wrote:You can saw through the metal sleeve at the outside of the bush to remove it from the lollipop.
Worked a treat cheers.
