What is the best way to black out the chrome window trim?
clydesdale
I am going to try to locate black trim, but can I paint it instead. If so, is there a common procedure. I have an 87 325is and I want to dechrome it. thanks
Ant
- Retired Team Member
get some UV stable semi gloss vinyl and do it with that dude, do it right and it will look factory for years to come.
You can paintthe trim, but the chrome needs a good keying and some etch primer for the finish to stay on.
HTH
HTH
Email FTW
d6dph
Talking of which, How did you get on Ant?
Ant
I've done 1/2 the car Dave, still not made the time( ok , cant be arsed ) to do the other side
one day mate, dechrome rightness all round
Email FTW
clydesdale
please further explain the vinyl. Is it also a paint? How is it applied? Thanks
geo1400
Yes, interested in the vinyl aswell... explain please?!
d6dph
The vinyl is the same stuff that i use to make vehicle graphics out of, its a very thin sheet and is very easy to mold tol the shape of the trim, if it needs to be shrunk into corner sections it can be done with mild heat.
I saw the parts Ant had done last night and they look spot on.
Project_E30
Do you have to remove the trim from the car to get this plastic sheet around it?
WerkdE30
im in the process of doing this ive rubbed back all the chrome with wet/dry paper im going to spray with primer then mat black paint. hope it goes well. unfortunatly the process has taken a number of weeks because whenever i go to spray it its either too windy or raining ...
