Hi i have an 89 316i that sometimes cuts out while normal driving (just cuts out dead) then picks up (without doing anything) then cuts out. this happens a couple times then picks up and drives normally again? also sometimes its hard to start and i haer a sort of banging noise coming from the back endof the car!? after a few minutes it will start!?
Also my speedo works intermitenly sometimes on sometimes off its up and down like a damn yoyo!!
(where is the sensor/connections) the haynes manual didnt help much
Any ideas on the above would be a great help cheers
