head gasket i think
DJ_B4L
Post Thu Aug 24, 2006 1:35 am
i seen a bit of light brown colour oil on the engine oil cap and a bit on the rad cap its not fully mixed the car hasnt over heated and when i check the oil in the dip stick its clean
does this indicate that its on its way or is it leakin a bit is there any product i can use to fix this or stop it from leaking ?
i know i need to get the head gasket done otherwise
how long does this job take to do can it be done yourself
DJ_B4L
Post Mon Aug 28, 2006 11:49 am
any one?
votivequagmire
Post Mon Aug 28, 2006 12:27 pm
Hi
It does sound like there is a bit of leakage somewhere.
There isn't enough evidence to say where it could be though. Have you had the pistons checked for compression yet?
You don't mention what the specs on your car are either.
M10? M42? Engine
DJ_B4L
Post Mon Aug 28, 2006 1:00 pm
sorry mate its a m20 325i G reg its only done 102 miles
i havnt checked the compression yet i got the tool to do it
how is it checked again?
320Touring
Post Tue Aug 29, 2006 9:29 am
hmm, sounds like it may be a head issue rather than a gasket..
the 885 head found in the 325i has a habit of cracking if not looked after properly.
I'd try flushing out and replacing the coolant, so you can see if it gets oily quickly..
As for fixing it- are you keeping the car? if not, PM e30beemerlad- he knows a product you can bung in the coolant to seal it temporarily
good luck and let us know what you find
DJ_B4L
Post Tue Aug 29, 2006 10:53 am
the thing is i checked the coolant didnt show any signs of it when i took the rocker cover off it showed quite a bit on the back of the rocker cover
when i check the dipstick there was only a dot of it on there but the rest of the oil is ok
how long does that temporary thing last?
is there any other way of repairing a cracked head. it couldnt be the gasket leaking from a small spot
dazleeds
old skool raver
old skool raver
Post Tue Aug 29, 2006 11:03 am
www.oldskoolfantasy.co.uk
320Touring
Post Tue Aug 29, 2006 11:08 am
dazleeds wrote:http://www.kalimex.co.uk/section.html?s ... 4.&pgid=17
nuff said problem solved :D
I couldnt remember the name of that stuff :D
thats why I said to PM lee-forgot you had betty too :mad:
dazleeds
old skool raver
old skool raver
Post Tue Aug 29, 2006 11:11 am
bloody good stuff
i certainly reccomend it
if it can handle lee for over a year and several months of me hammering the car too then its spot on :D
and for £7/£8 theres no better fix in my oppinion
Daz
DJ_B4L
Post Tue Aug 29, 2006 11:32 am
is this the stuff Image
where can i get it from hlafords or any other places
its for my bros car so il speak 2 him n tell him he can either get it repaired or use this
thanks guys
dazleeds
old skool raver
old skool raver
Post Tue Aug 29, 2006 11:35 am
DJ_B4L wrote:is this the stuff Image
thanks guys
thats the stuff mate
not sure if halfords do it but worth checking
most motor factors i go to have it on the shelf somewhere tho
was put in lees 325i then driven very hard for over 18months by lee and then myself and not once did she show any signs of overheating etc as she had prior to using this stuff
worked a treat
DJ_B4L
Post Tue Aug 29, 2006 12:17 pm
its werid because my car didnt show any signs of overheating the temp needle was in the middle
oh wel
il probably give this a try or doing the head any one can help me do this job?
