Gearbox Oil Diff Oil Engine Oil Recommendations please (M20)
alpinac227
Have an E30 ALPINA C2 2.7 based on a 325i M20 with about 65,000 miles and want to change all oils Gearbox Diff Engine PAS recommendations please..? Gearbox changes are a bit stiff, wondering maybe incorrect oil, car has been stood sometime would this be possible cause.
FlappySocks
There are lots of recommendations if you search for it. Depends how stiff your change is. Second gear can sometimes be a problem, and reading on the forum, ATF fluid is an option.
Stuart.
Stuart.
stuartgallafant
Project_E30
Stuart do you know what quanities are needed for the gearbox and diff?
stuartgallafant
Motronic to Megasquirt Plug and Play Guide
