"just the backing plate making contact"
then that would surgest your wheel bearing is shagged and if its not then fitting a buckled wheel will soon fuck it up.
If you didn't have the rubbing before you changed the wheels what do you think it could be
Check the steering rod and the inner edge of the rim.
There is NO nucleus.
