engine just cuts out
beemertom
Post Sun Jul 30, 2006 5:43 pm
i had this problem yesterday and its done it again today.drivin down a dual carriageway and then the engine cuts out and nothin.pulled over started fine an away i went again.need some help as i shit the bed cheers
P_VIDDY
Post Sun Jul 30, 2006 6:19 pm
sounds like a dodgy earth, have u checked all ur power and earth are tight on ur battery etc
Cloggy Saint
Post Sun Jul 30, 2006 6:26 pm
I get the same thing now and then, and was advised to check the dme relay.
Markey
Post Sun Jul 30, 2006 6:32 pm
I had this and it was the fiel pump. It was ok until it started not to start again then i replaced it.
beemertom
Post Fri Aug 11, 2006 6:40 pm
changd fuel filter,checked earth and cant find relay should i get it plugged in need to get it sorted for gaydon
jon_pure_british
Post Fri Aug 11, 2006 6:46 pm
exactly the same as mine, i changed filter and pump and now works
Clacton-On-Sea
Essex
cass1_5503
Post Fri Aug 11, 2006 7:14 pm
same thing as it did to me it turned out to be the fuel pump, hope u get it sorted in time for gaydon
beemertom
Post Fri Aug 11, 2006 8:33 pm
sound shall try this 2moz
