car speed sense line
DJ_B4L
Post Thu Jul 20, 2006 1:15 am
i need to know where i can locate the car speed sense line which show how fast the car is going as i need to connect this wire to my sat nav and which wil show the sat nav accurectly and the location as i move according to the speed
Zayyan
Post Thu Jul 20, 2006 1:29 am
This may not help, but surely your sat nav can display your speed anyway?
It will display less than the speedo does as the speedo overreads, but it's accurate to within 1km/h I believe?
alane
Post Thu Jul 20, 2006 6:15 am
the sat nav readout will be more accurate than the speedo sensor -there usually bet 5 & 10 mph out
Post Thu Jul 20, 2006 9:02 am
something to do with the sat nav continuing to work when it loses satelite signal, IIRC.
Speed signal is available at the green connector at the back of the speedo.
Late cars with ISO radio connectors already have a connection there for speed sensitive radios. Blue wire, I think.
Also comes out at pin 10 of the white connector and pin 26 of the yellow connector.
a
kam325itouring
Post Thu Jul 20, 2006 4:04 pm
which sat nav is it?? if it is pioneer avx-1 is does not really need speed pulse for it to work, it will work off the gyro in the brain box and gps.....
But any way all bms the speed pulse wire is either at the dash radio position or behind the clocks usually black with white stripe, thats is the colour on all the ones i have done!! (e30,e36,e34,e39,e46)
DJ_B4L
Post Thu Jul 20, 2006 10:46 pm
yeh its a pioneer avic -x1 it tells you the direction but on the manual it says if you dnt connect it, it wont be on the correct spot it doesnt really need to tell how far you are going it just makes it accurate so it knows how fast and far you have moved since the last locatiion
kam325itouring
Post Fri Jul 21, 2006 10:05 am
i,ve fitted probably 60/70 if these things, 99% of the time i do connect the speed pulse... as i explained the nav will work with out speed pulse and will be just as accurate. the only real reason speed pulse is connected is cos the nav will have three inputs speed, gps and gyro, so if one goes down it still has two as back up e.g. if you were going through a tunnel..... where have you fitted the brain?? make sure it is flat and pointing the way it says on the unit.
did you find the speed pulse wire?? do you know how to check the wire with the nav?? if not i will explain to you :)
DJ_B4L
Post Fri Jul 21, 2006 11:15 am
hi mate i have fitted the brain box in the glove box only thing is if i put it the corrrect way the arrow isnt were it should be on the road it shows it off the road if i move it around till i get the arrow stright and leave it like that then it tells me the route correctly what could be wrong here?
kam325itouring
Post Fri Jul 21, 2006 11:31 am
the thing with these brains is that you have to lay them flat too!! you got a bit of tolerance but not much. where i put them on e30s is under the passenger seat. take the seat out (4 bolts) lift the carpet, cut the foam for the brain to sit in and secure it in. the leads will be long enough. is the avic new or second hand?? if it is second hand then you have to go into the calibration menu and clear the learning status, cos it will still have memory from the previous car. when you initially put an avic in it has to learn calibrate so it may be a little inacurate to begin with. it will even learn your driving habbits!!!! as in if you take the came route every day it will remember it! clever piece of kit it is.
DJ_B4L
Post Fri Jul 21, 2006 3:33 pm
yeh its used a brought it of someone that only used it for about 2-3 months and is in very good condition
how do i get into the calibration menu?
that basically deletes all the previous trips and gps history?
kam325itouring
Post Fri Jul 21, 2006 3:58 pm
yeah thats what you need to do...basically its still reading off the old history..... you need to go into the information menu and go to 3d calibration status, and clear the top 3 menus, then the nav will go back to learning status. oh and keep that nav disc in mint condition a new one is 250 quid!!!!! :cry: you can go to connection status and see how many sats you are picking up and if everything is connected properly.
DJ_B4L
Post Thu Jul 27, 2006 12:31 pm
hi mate i did that thanks alot it
helped and is now so accurate also one more question how did you stop the screen hitting the indicator stalk as i have to hold mine back each time the let the screen come out or goes in?
kam325itouring
Post Thu Jul 27, 2006 2:33 pm
no probs gezza!!
sorry dude this is the downfall of putting a flip-out screen in a e30!!!! if you figure out a way let me know.......
Martinaston
Post Thu Jul 27, 2006 2:45 pm
Get a dash facia from a left hand drive car so the clock/OBC sits on the right.
There is NO nucleus.
jordano
Post Thu Jul 27, 2006 3:45 pm
kam35 touring do you know anything about the alpine multimedia units
worrying is like a rocking chair, it gives you something to do but it never really gets you anywhere
kam325itouring
Post Thu Jul 27, 2006 4:53 pm
good thinking martinason!!!! never thought of that!!!! :cool:
kam325itouring
Post Thu Jul 27, 2006 4:56 pm
Yeah i do jordano what do you need to know?? pm me or post a reply.....
