has anyone ever tried this??
or had an engineer look at them to see if its possible??
i need the hubs to accept 4x108 rather than 4x100
what ya reckon any ideas??
dnt really want 1 inch adaptors to solve the prob
cheers
Daz
redrilling e30 hubs
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
Turbo-Brown
- Boost Junkie
I had a look last week as it happens.
Really don't think there's enough meat around the outside to accept a 4x108 safely to be honest.
Think your only options are either adaptors, and if it were me I'd have them made from steel instead of alloy considering the stresses they're under, or to have new hubs made.
I did consider making making some alloy hubs drilled to 4x108, but decided a better idea was to move my engine back by about 400mm instead
EDIT> thought I'd answered this one yesterday on a mate's computer thinking about it, or did I imagine that?!
mark320i
alrite daz you wana increase it by 8mm yeah?
just so happen to be an engineer lol
Turbo-Brown
- Boost Junkie
Problem as I see it is that the holes are right on the edge anyway, and taking them 4mm closer leaves then with absolutely bugger all material around one sidemark320i wrote:alrite daz you wana increase it by 8mm yeah?
dazleeds
- old skool raver
ok yeh that makes senseTurbo-Brown wrote:Problem as I see it is that the holes are right on the edge anyway, and taking them 4mm closer leaves then with absolutely bugger all material around one sidemark320i wrote:alrite daz you wana increase it by 8mm yeah?
so is there any 4x108 hubs out there that could be fitted instead??
im sure i posted this q as well but couldnt find the post
Turbo-Brown
- Boost Junkie
Wouldn't be possible to adapt something from a Sierra would it?
Tis the first car that springs to mind with the right PCD (I think!) and RWD so that it doesn't have a driveshaft running through the middle of it.
Think the gods of automotive bodgery really would have to be grinning down on you for it to be a straight swap though!
jaistanley
I think your safest bet would be some sort of audi to golf mk2 adapter/spacers from germany.
Trouble is they may reduce your offset too much making the wheels stick out. I spose you could then have some machined from the inside of the wheel by a re-furb place.
Have you already thought of this?
