325i suspension replacement
can any one help? my 325i has been lowered by a previous owner & i dont know what springs etc where used . the ride height is fine but it could do with being replaced (on a budget) any ideas on (a) original ride height? (b) what to replace it with i thought abought g-max but dont know if its any good? i know you only get what you pay for but cash is a bit tight at the moment the car is a 325i coupe 1989
- Contact:
Gmax springs are OK!!
For the rear, go to GSF or Euro car parts and get youself a set of gas struts there only abour £20odd quid each and they sit lowered springs nicly!!
There is an Ebay shop that sells good springs for cheap!!
(Don't touch the shocks!!! There CRAP!!)
Dont put cheap shocks on the front!! it will cause you loadsa problems!!
Go for a good set!!
ile post up the ebay shop in a min....
Go for a good set!!
- Contact:
If the ride height is ok, why are you wanting to change? Are the dampers fcuked or something?cozmic wrote:can any one help? my 325i has been lowered by a previous owner & i dont know what springs etc where used . the ride height is fine but it could do with being replaced (on a budget) any ideas on (a) original ride height? (b) what to replace it with i thought abought g-max but dont know if its any good? i know you only get what you pay for but cash is a bit tight at the moment the car is a 325i coupe 1989
- wullie325i
- CAUTION - unreliable trader!
hi
get a spax psx kit i got one that lowers my car by 40mm and the shocks are 28 stage adjustable.its a really good setup.
wullie
wullie
like you need 28 different settings
the spax kit is £350 though and he did say money is tight.i had the spax kit on my touring and i found it to harsh even on the soft setting so i changed to bilsteins and its good now
