When im not moving and rev up it glids through but when im driving the car it seems to jump now and then
Any thoughts
Could i just take apart the dials and clean up the needle and move around a few times to free up??
Neil
Rev counter's Jumping
cliffybabe
- Powered by Nelly
stuartgallafant
robmpulse
does it do this the same time you are hitting larger than normal bumps in the road?
Danny06
My own sport would do the same but woz told from a few different people that it because i have a high lift cam fitted
Turbo-Brown
- Boost Junkie
Cam shouldn't make a difference I wouldn't have thought, a lumpy cam shouldn't make the engine speed jump about that much!
Mine seems to move up smoothly, but sometimes you can catch it moving down in a series of kinda steps.
Just put it down to the Emerald ECU to start with as I'd not noticed it happen when the car was standard, but I wonder now having read this.
I wouldn't ask these few different people for any more car advice, if I were you!Danny06 wrote:My own sport would do the same but woz told from a few different people that it because i have a high lift cam fitted
Unplug and reconnect the C101 connector on the bulkhead a few times.
The tacho needle is driven by a couple of gears. On one occasion I had one that stuck occasionally due to a small piece of grit in between a couple of teeth. Would expect this to be better when moving though, not worse.
cliffybabe
- Powered by Nelly
cheers guys for the posts.
I have a go at that tomorrow thanks Brian
