Hi Guys
I've bought a tech 1 kit off a quality fellow zoner, which will be here soon, i wanted to know how many people have put this kit after market??
Neil
Any Tip's on Fitting a Tech 1 Kit??
cliffybabe
- Powered by Nelly
Theo
Ive fitted it, it has its tricky moments but isn't too difficult. I used carbond to fit the sideskirts, as opposed to drilling the body work - which I would recomment doing (you also need to use the clamps on the sill seam as shown in the etk diagrams). The front and rears are fairly straightforward, but would take all night to describe in detail the process for removal and fitting. If you have any problems just post up here and I should be able to help!
cliffybabe
- Powered by Nelly
cheers theo its alreayd been removed onc, it get here a quick clean and see how it matched up to my paint work if cool it will go on if not quick spray up thne it will go on
cliffybabe
- Powered by Nelly
no one else got any helpful hints????
Theo
One thing that is important to remember is that you must have the correct rear bumper rubber end caps when you fit you rear skirt. The standard ones are no use as they foul the mtech skirt. Hopefully you will have got these with your kit, otherwise you will have fun and games trying to track a pair down.
cliffybabe
- Powered by Nelly
oh, i didnt know that one
