Early Gear Box
GeoffH
Post Fri Jun 30, 2006 7:10 pm
I have a 325 manual box from an 87 D reg Sport, is there and difference between this box and the ones found in the later face lift cars say H or J reg
Cheers For your Hepl
Geoff H
GMH Autos
Cheadle, Stoke-On-Trent
Mechanical work, Servicing, M.O.T Repairs
01538 753958
BMW_YARD
Post Sat Jul 01, 2006 10:06 am
The early motronic had dual crank sensors and these were located in the bellhousing of the gearbox to sense of the flywheel and timing trigger.
If you have an early car (twin sensor motronic) you'll need the gearbox from an early car.
An early box will fit a late car but the sensor holes will not be used.
m-dtech
Unapproved Trader caution
Post Sat Jul 01, 2006 1:44 pm
BMW_YARD wrote:The early motronic had dual crank sensors and these were located in the bellhousing of the gearbox to sense of the flywheel and timing trigger.
iirc later boxes still have the holes for the sensors ??
