Basic question re immobiliser - broken?
PaulyV
Post Thu Jun 29, 2006 8:54 pm
Hey there,
Pals has a 318i Touring, with an aftermarket immobiliser. The type as a PCB which slots in just under where the key is.
The car lights and electrics work but it is not turning over when the key is turned - I am thinking it is the immobiliser - could anyone confirm or deny this possibility?
best
Pauly
1990 318i LUX, Alpine White, 80,000 miles, as close to mint as I'll ever get.
Post Thu Jun 29, 2006 11:26 pm
Depends how this immobiser is connected!
Could be, or could be the ignition switch.
The starter motor wire is a thickish black/yellow wire.
Take the cover off the top of the diagnostic socket under the bonnet and short together pins 11 and 14 with a short piece of wire.
This should turn the engine over, and start it if the ignition switch is on.
