F** Starter motor
e21Jason
Post Wed Jun 28, 2006 11:34 pm
Hi Teh starter motor on my touring has packed up it spins but the solinod does not engage.
How do you get it of I jst spent 3 hours trying, I can get to the nut with a stuby wrench but i can not get onto the head of the torx bolt.
Is there any tips to do with startigntostrip pipes & wires out of the way
Jason
Post Wed Jun 28, 2006 11:43 pm
The ring end of a certain size of AF combination spanner will fit the torx bolt good enough, IIRC, but the other way is very long extension bars from the back end of the gearbox. Release the gearbox crossmember if necessary.
e21Jason
Post Wed Jul 05, 2006 12:43 pm
Ended up droping the hose from the back and gettign in with a swan neck torx spanner
Jason
irish320i
Post Fri Jul 07, 2006 6:40 pm
i think you can get it by griping the torx side with a pair of long nose vice grips and opening it from the nut side done mine not to long ago and that s how i got it as i have no torx spanners
