m50 transplant
Guest
Post Mon Mar 07, 2005 3:39 pm
does anyone no where to get a m50 engine for cheap? what else would i ned besides the engine and ecu.
Ant
Retired Team Member
Retired Team Member
Post Mon Mar 07, 2005 5:23 pm
Engine complete with all ancils, ECU, Gearbox to match and a tall final drive of around 3.25:1, the e36/39 style gearbox run V low gearing hence the tall back end requirement
I'm moving this to tech help for more exposure dude.
6potWil6pot
Post Mon Mar 07, 2005 5:52 pm
As what Ant said and a smaller diameter brake servo too as the standard one will be too big to fit beside the engine.
I have heard peeps saying the M20 gearbox mates, thus ridding them of the need for a 3:25 LSD...
Post Mon Mar 07, 2005 6:20 pm
m20 box fits jus gotta mod the gear lever and gearbox mount to account for the 10% angle it creates..
Guest
Post Mon Mar 07, 2005 7:26 pm
can one of you guys tell me some good mods to put in a 325es if not will i need to do surgery on the engine bay and do a swap?
Post Mon Mar 07, 2005 7:37 pm
if your looking to keep the m20
6 branch exhaust manifold, exhaust, cam, bigger throttle body, 2.7, MAF conversion/standalone ecu
you can extract 220bhp (is the highest i've heard of..) albeit plenty of Ԛ£Ã”šÃ‚£
jamesroools
Post Mon Mar 07, 2005 7:42 pm
http://www.theeurodepot.com/e30m50.html
they do everything you need for an m50 swap
Image Image
Guest
Post Mon Mar 07, 2005 7:43 pm
tell me the site where i can find that stuff for the 325es
thanx chris
e30_Turbo
Boost Junkie
Post Mon Mar 07, 2005 7:45 pm
US_e30 wrote:can one of you guys tell me some good mods to put in a 325es if not will i need to do surgery on the engine bay and do a swap?
Is that a 325is or 325es......will determine what head and bottom end mods you need :thumb:
Post Mon Mar 07, 2005 8:38 pm
just realised he's already got the 2.7 lump..
stick a 325is head on there with the associated ecu etc n you got a cheap 2.7 conversion lol
cant remember whats involved exactly tho soz
Post Tue Mar 08, 2005 12:26 am
LH drive M50 conversions have different problems than RH drive cars.
The left hookers don't have problems threading the steering column through the exhaust manifolds, but they can't move the brake master cylinder like you can on a right hooker.
Best way to get a M50 engine is a written off 525i, but you will need the alloy engine mounts and exhaust manifolds from an E36.
6potWil6pot
Post Tue Mar 08, 2005 12:30 am
Mines got the E30 rubber engine mounts! Altho id prolly get them switched for the alloy ones sometime!
Guest
Post Tue Mar 08, 2005 12:36 pm
my e30 is a 325es and thats why im having problems with parts ive search every for parts for it. the 2.5 heads on my 2.7 block will make it run like the 325is 2.7 conversion?
Guest
Post Tue Mar 08, 2005 12:44 pm
i mean mods not parts sorry
Jimbob
Post Tue Mar 08, 2005 1:15 pm
If you have the 325es then surely you can build a 2.7 if you get can a 325i head from a scrapyard.
Guest
Post Tue Mar 08, 2005 1:41 pm
every thing would match up right so i wouldnt have to get anything but the head and ecu? could i then use some 325is parts?
You guys have been so helpful thanks alot
chris
Toby_Unna
Boost Junkie
Post Tue Mar 08, 2005 2:00 pm
ha ha this won't help you much (sorry!) but it is engine swap related! i just polished my m30 cam cover a bit so i thought i'd put a pic up.
Image[/list]
