Remving de chrome trim
demonbiker
Post Sun Mar 06, 2005 9:49 pm
whats the best way to get the trim off without damage- got one side off but had to bend it a little- will be fine to refit(didnt kink it!)
:roll:
'90 M5 3.6 "Driven Hard......Put Away Wet!! "
pete325i
Post Sun Mar 06, 2005 10:42 pm
I've just used some black insulation tape, if done carefully can look really nice.
Pete
luxconvertible
Post Mon Mar 07, 2005 10:48 pm
best way to do it is with a bit of plastic i personally use filler spreaders at work then lift up with a trim tool or a blunt scew driver!![i work in a body shop and remove quite a lot of trims!!]
good luck Ben
demonbiker
Post Mon Mar 07, 2005 10:59 pm
will it give it a go cheers!
