Does it matter which way round the front springs are fitted ?
Do they have a "Top and Bottom" ?
Quick H&R 60/40 Cup Kit Question
kam-325i
bigdek
yes .
make sure the writing is the correct way up
kam-325i
So the "Tighter" wound part of the spring is the top.
Geeman
The top of the spring should be flat... where as with the bottom part, the end of the coil 'should' sit into the indentation in the shock cup... make sense?
kam-325i
Neither end of the front springs have been made flat.
The coils are tighter on one end, would this be the top ?
M5pilot
Just read the writing, it needs to be the right way up.
The shorter coils go at the top.
