no indicators!!!
Guest
Post Sun Mar 06, 2005 5:31 pm
whilst parked up ,with my left indicator flashing,they all of a sudden stopped working.checking fuses ,the indicator 15amp fuse was blown,so i put a new one in which straight away blew when i put the ignition on and tried indicating so i imagine there must b a short on the indicator circuit.any1 else come across this??and where prob was??
Dom
Post Sun Mar 06, 2005 6:41 pm
just had this problem myself. Check the glovebox light switch isn't earthing out.
Davenotouring
Post Mon Mar 07, 2005 12:21 am
Make sure the hazard light switch is in and connected properly?
After you've had the dash apart and that, it may be loose?
BMW 328i Cab - Daily Slag
Jimbob
Post Mon Mar 07, 2005 1:14 pm
I remember when I was installing a chip and plugged the ECU back in, pinched a wire when slotting it in causing the indicators to go mental.
Post Tue Mar 08, 2005 12:38 am
If the fuse only blows when you switch a particular side of the indicators on, then the fault could be anywhere between the indicator switch and the indicator lamps themselves, and the instrument panel warning lights.
A good place to start would be the alarm, if this flashes the indicators, considering the quality of most alarm fitters work that I come across.
