lacking power
E30GAV
Post Sat Jun 03, 2006 3:31 pm
hi guys ive got an 1990 e30 316i.
the problem i got is, wen my car is doing between 3500 to 4000 rpm its mis-firing. and it keeps on doing it.
but in the mornings when the engine is cold, i can stretch the revs out all the way to bout 5500-6000 rpm, but as soon as the engine warms up it sarts mis-firing again.
can anybody help me with this. proper piss take, i get little novas and crappy cars taking me at the lights!!!! :x
Gav
Ant
Retired Team Member
Retired Team Member
Post Sat Jun 03, 2006 7:04 pm
Hi mate, welcome to the site !
your car has the M40 engine, its is known to have camshaft issues that could cause the above, more on that in a moment
you say the car is fine until warmed up, if the coolant sensor has failed then the engine will be running very rich all the time ( when warm) this would cause a big drop in power output so may I suggest you replace the BLUE coolant sensor on the head ( look under inlet ! ) before anything else.
Now, assuming the above did not make any diff, with the car in neutral and fully warmed up, floor it, if the engine still wont rev over 4-4.5K , then the cam is probably worn out I'm afraid
Try the sensor, and get back to us M8
HTH
E30GAV
Post Sun Jun 04, 2006 1:54 am
ye it seems lyk its running proper rich, stinks of fuel hardcore when i put ma foot down. but yeh il giv that coolant sensor a looking at and let ya know what happens! nice 1 mate!
Gav 8)
