HELLO TO ALL : WHERE CAN I OBTAIN " tool " TO REMOVE LARGE
RUBBERS THROUGH AXLE
REAR axle bushes
Project_E30
Where are you?moya wrote:HELLO TO ALL : WHERE CAN I OBTAIN " tool " TO REMOVE LARGE
dazleeds
- old skool raver
get a 30mm plus socket and knock them out with that
or alternativelt an old head bolt if ya have one lying around
head bolt is also perfect for removing the trailing arm bushes
hth
Daz
hth
Daz
www.oldskoolfantasy.co.uk
moya
thank you for advice-but am seeking the tool to make job easier
oze30
how does the old head bolt work daz?
dazleeds
- old skool raver
no worries
but i got out all the bushes very easily as stated above
took about 30 mins the lot
dazleeds
- old skool raver
stick the bolt thru the centre of the bush and clout it fellaoze30 wrote:how does the old head bolt work daz?
then when the axle bush is half way out a large socket 30+mm will help as the bolts too deep to still hit with the hammer
but once theyre halfway they will come out with 1 or 2 more hits very easily
with the trail arm bushes you only need the head bolt slide it thru centre and again a few clouts should free them up
if theyre still tight heat a little with blow torch and try again
i had hardly any tools when i did mine so had to find alternatives
but having done it this way i doubt i,ll ever try any other way now it was so easy
Daz
oze30
so this works for removeing said bush..
but what about replacing it?
Is it the same technique for the trailing arms bushes?
dazleeds
- old skool raver
yepp no reason why not mate
i tapped the axle bshues back in with the bolt and a piece of wood to protect the bush
get some fairy on them and they go in very easily
trail bushes same lil bit of fairy and the bolt and just knock em in fella
i had previously always paid at least £100 a tim just having axle bushes done cos i heard all the storys bout how impossible they are but was breaking a car so had a go meself
not hard at all, if your ok with the spanners youll do em no prob
hardest part is dropping the axle imo
Martinaston
That must have been some hammer
