whats this tool for?
smithy318i
Martinaston
Stiring paint
dips346
- London Meets Main Man
looks like its for a air flow metering unit
Jon_Bmw
- Dangerous when thinking
Hitting big brother contestants with, or people that want £6k for a 325 touring
Emotechnik
Closing your sunroof when you get a flat battery, use it with the screwdriver handle.
smithy318i
Nope. Thats the Z shaped one.Emotechnik wrote:Closing your sunroof when you get a flat battery, use it with the screwdriver handle.
Emotechnik
Dimensions?
You sure it's out of a BMW?
dazleeds
- old skool raver
i agree with Dips
would say airflow
prob has more than one use on an e30 tho
would say airflow
www.oldskoolfantasy.co.uk
smithy318i
21cm long. Deffo a BMW part. It goes in the toolkit inserted inside the spark plug spanner.Emotechnik wrote:Dimensions?
Radio Grub screw removal tool ?
Dan318-is
these are not found on 318is' for some weird info, there is no slot in the boot tool box for them
Emotechnik
End dimension or are you saying its about 3mm (like a radio grub screw)
smithy318i
3mm allen key end
gcorky
- Boost Junkie
- Homo Hair
is it magnetic?
smithy318i
Nope. Not magnetic.Jhonno wrote:is it magnetic?
Someone must know what it's for !
stonesie
electric window's???
noticed when changing my drivers mechanism theres an allan socket on there
smithy318i
nope, not that.stonesie wrote:electric window's???
paint? ( i might hav missed the topic on your progress)
bottlecapE30
i'm 99.9% sure it gos on the scewdriver handle and is used to ajust valves in the m20
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
But isnt the tool kit put together for 'roadside' repairsbottlecapE30 wrote:i'm 99.9% sure it gos on the scewdriver handle and is used to ajust valves in the m20
gcorky
- Boost Junkie
think your 99.9% wrong-how would you adjust the inlet valves with that-and there holes not allen head on the eccentric adjusters.throttle stop adjustment i say-as further up the thread!or radio plugs as you said,because its not in all cars and bmw in that day didnt supply standard stereo ,they were all an option-i think.bottlecapE30 wrote:i'm 99.9% sure it gos on the scewdriver handle and is used to ajust valves in the m20
Chris-W
Some BMW locking wheel studs have a cap secured by a 3mm hex bolt. Could be for that?
gcorky
- Boost Junkie
numbers on it?
http://www.samstagsales.com/bmwtools.htm
is it 5 sided or 6 at end?
radio or antenna key,but will adjust the hex throotle stops.
E30Mark
This has been discussed before, but i can't find the topic. I think it has something to do with the convertible roofs....
What car did it come from?
I'm sure it was Ian Hamilton who came up with the answer last time
PM for details
PM for details
This adjustment is set at the factory and never needs to be changed, so why would BMW provide a tool in the "roadside repairs" toolkit for this?gcorky wrote:throttle stop adjustment as per m20 etc?
Early type electric windows had a provision for manual overide. It'll either be for this, or, as E30Mark says, something to do with rag top roofs.
gcorky
- Boost Junkie
Brianmoooore wrote:This adjustment is set at the factory and never needs to be changed, so why would BMW provide a tool in the "roadside repairs" toolkit for this?gcorky wrote:throttle stop adjustment as per m20 etc?
never needs to be changed -wow
lol,read all the thread brian!!!so do you strip down your doors at roadside,if you do you can travel with me m8???
you prob right tho.i just saying what it would fit.
gcorky
- Boost Junkie
[img][img]http://img139.imageshack.us/img139/2517 ... ize5tw.jpg[/img][/img]
i dont have one anyway i carry this instead,fixes most roadside jobs :mad:it is strapped where the spanners were.
