Powerflex ARB-mounts PFF5-302-19B don't fit?????
StevieNL
Post Mon May 15, 2006 4:55 pm
Quick question:
Bought and fitted the Eibach Anti-Roll-Kit a few weeks ago. The poly-bushes supplied in the kit for the front bar don't fit the e30 brackets, so I ordered Powerflex PFF5-302-19B to have them drilled to the correct ARB diameter.
Upon arrival the Powerflex bushes have the exact same outside shape as the Eibach bushes, and thus will not fit the e30 mounts. I did notice on the box that Powerflex says they fit both e30 and e36, and I know the e36 uses a different bracket, same as on my e34, that probably does fit these bushes......
So am I supposed to use the e34/e36/etc mounts with these bushes? Anyone else had this problem? Tried the search function here but no suitable answer popped up......
Thanks,
Steve
ed325i
Post Mon May 15, 2006 5:07 pm
Hi, Are they a diffrent shape to the rubber BMW ones you removed? Mine fitted ok.
ED
StevieNL
Post Mon May 15, 2006 5:17 pm
ed325i wrote:Hi, Are they a diffrent shape to the rubber BMW ones you removed? Mine fitted ok.
ED
Yes. I actually went back to the skip I had just ditched the stock ARBs in and took the BMW-bushes out to use for the time being. The originals have the thick bit in the center, the Eibach and PF have the thick bits on the outside and are slim in the center.
calder
Post Mon May 15, 2006 5:28 pm
assuming that these are otherwise the same as for a BMW ARB these will fit, they're just a bit of a pig to get in.
You may need to do some careful trimming to help things along, i found that an angle grinder is just the thing to trim polybush.
you may then need a trolley jack or molegrips to compress the bracket round the bush, it takes a bit of persuading.
calder
StevieNL
Post Mon May 15, 2006 6:00 pm
calder wrote:assuming that these are otherwise the same as for a BMW ARB these will fit, they're just a bit of a pig to get in.
Thx for the reply.
Thought of cutting them up but there must be a reason 2 suppliers send an identical part. Do the e36 brackets fit the e30 mounting holes? If that is the case I'll just get those and fit the stuff properly......
ed325i
Post Mon May 15, 2006 6:03 pm
Mine are the same thick bits on the outside and slim in the center, they are a tight fit.
Ed
calder
Post Mon May 15, 2006 10:17 pm
sorry, no idea on E36 bits
calder
stonesie
Post Mon May 15, 2006 10:21 pm
Slightly different but i have just got a new set of bushes and clamps from bmw for mine and i am not looking forward to fitting them at all :mad:
I decided to trial fit a bush to a clamp and i needed a vice to do it and thats without the bar itself..... washingup liquid methinks, soap it up and ram it in :wink:
StevieNL
Post Mon May 15, 2006 11:02 pm
Ordered the e31/e32/e34/e36 clamps, and will post with pics if the provide a proper fit. Can't be bothered to cut up new bushes if ┚¬5.- clamps will make them fit properly.....
I'll keep you posted.
stonesie
Post Mon May 15, 2006 11:26 pm
mine were 81p + vat
£5.95 all in for 2 bushes and 2 clamps......... trade discount rocks :bmw: :rock:
FlappySocks
Post Tue May 16, 2006 9:37 am
Any idea which Powerflex bush I need for a standard Sport ARB? I think the ARB is 20mm, and the bushes come in 19 and 22mm.
Stuart.
ed325i
Post Tue May 16, 2006 1:20 pm
FlappySocks wrote:Any idea which Powerflex bush I need for a standard Sport ARB? I think the ARB is 20mm, and the bushes come in 19 and 22mm.
Stuart.
They come in 3 diffrent sizes.
FlappySocks
Post Tue May 16, 2006 1:34 pm
ed325i wrote: They come in 3 diffrent sizes.
Yes, 19, 22 and 24 mm
For a 20mm ARB, do I go for 19mm and drill it out, or is 22mm ok?
Stuart.
chu346
Post Tue May 16, 2006 2:47 pm
I've fitted some H&R ARB's and the bushes were a B*tch to fit, until I figured it out. You need to fit the ARB on the car as a trial fit and mark where the bushes go on the ARB, then lay it all out on the ground, put the bushes on the ARB then put the bracket over the bushes and grab a sledge hammer. Beat the bracket around the bush with the bush on the bar, repeat for the other side then fit to the car. Longer bolts would help with this to aline the bracket up.
Piece of cake once I knew what I was doing.
