How to get FAT sparks constantly ?
haffeel
Post Wed May 03, 2006 2:51 pm
My ride E30 325i Auto works pretty good when going around town or long distance over motor way so long I dont switch on the Air Conditioner.
But I live in a warm climate so sure I must use the Air Con, but the sad story is I could drive the car with Air Con ON for about an hour after that the car feel very lumpy, practically drags.
To get back to original spirited driving, I must drive around at least 2 hours without Air Con ON. which means it takes that long to charge the battery full
I had this same problem in a previous Japanese Car, what I did was to replace the original 60amp alternator with 80amp alternator.
Can I do the same to my E30 325i Auto? What amp alternator should be sufficient?
Or is there other alternative?
thank You All
Post Wed May 03, 2006 6:54 pm
Would have thought your car already had a 90A altenator as standard.
May be worth checking it hasn't been swapped for a smaller one at some time,or that it's not faulty.
haffeel
Post Thu May 04, 2006 12:28 am
My ride took an upgrade path from E30 320 1984 manual with Air Condition to what it is now E30 325i Auto a with 1989 engine, so is it possible originally it had a lower rating Alternator and now it is effecting.
Any idea how to check what rating my alternator is currently ?
Post Thu May 04, 2006 9:11 am
haffeel wrote: Any idea how to check what rating my alternator is currently ?
Should have a lable stuck to it, which might possibly be colour coded.
An 80A I have has a white label, One (unreadable) on a 316 is blue.
