When i indicate left the indicator is flicking 10 times quicker than it should. I noticed that the back is flashing as is the side repeater but the front indicator is not. Is it a case of changing the bulb or is it the relay/fuse? Where do i start to look?
Thanks in advance.
indicator flicking abit TOO quick!?
Giggz
Nice one mate. Bloody hell that was a quick response! Will get it sorted tommorrow.
May not even need a new bulb.
E30 front indicators aren't particularly waterproof, and, although the lamp holder doesn't corrode, the lamp does.
Try cleaning the metal parts of the lamp before you bin it.
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Brianmoooore wrote:May not even need a new bulb.
And your top tip for the day is dab a bit of grease over the end cap of the bulb and it won't corrode again.
Taylor.
Taylor325i
Taylor325i wrote:Brianmoooore wrote:May not even need a new bulb.
And your top tip for the day is dab a bit of grease over the end cap of the bulb and it won't corrode again.![]()
Taylor.
Or if you wanna be anal about it (pardon the punn) and not use grease then vaseline works just as good.
Taylor.
Silicon grease is the stuff to use.
