318is timing
keggy
Post Thu Apr 27, 2006 10:53 pm
can ne1 tell me how to seting the timing on an m42 engine? :wink:
Ant
Retired Team Member
Retired Team Member
Post Thu Apr 27, 2006 11:47 pm
asume you mean cam timing ?
you need some special tools mate......
8mm drill bit to lock the flywheel up( hole is under starter in block webbing )
Straight steel rule.
lock flywheel, use straight edge, on edge accross the flats @ the rear of the camshafts,
Job jobbed
keggy
Post Fri Apr 28, 2006 8:08 am
yeh thats wot i mean thanks :)
keggy
Post Fri Apr 28, 2006 5:27 pm
ne1 know where i can find torque settings?
