Petrol Advise Please...........
Stoney_god
Wed Apr 26, 2006 1:32 pm
Since having my 325 Tourer Suprchipped I now manage around 170 miles per £40.... The car doesn't smell like it's running rich at all though.. Not good I guess ???
Also when I remove the fuel cap it makes one hell of a suction noise..
I've owned plenty of other E30's and have never experienced this on the same scale.. Anything to worry about ?? :mad:
TVRTASMIN
Wed Apr 26, 2006 5:01 pm
Sounds bad to me. My 2.7 Tourer does about 300 miles for 50Litres of Shell Optimax. More on a proper run.
If the chip has not been properly mapped for your engine, all it will do is chuck more fuel in. Might be better with a Zone chip.
TW166Y
Wed Apr 26, 2006 5:08 pm
my touring is shite on fuel too... can anyone help as to things we should check? i get about 120miles to £25 :? obviously a bit more on a run but not much more
Saying goodbye to 4-pot wrongness
e30-320i
Wed Apr 26, 2006 5:32 pm
same here guys 100 miles to £20 changed thermostat dizzy cap rotor arm checked for leaks etc still no real change
20p a mile aint good
89 325i touring
TW166Y
Wed Apr 26, 2006 5:35 pm
8O oohhh dear :cry:
dazleeds
old skool raver
old skool raver
Wed Apr 26, 2006 5:40 pm
yep i gotta agree
betty is sucking the cash outta me on every drive :cry: :cry:
but saying that i do spank her everywhere winkeye
still a touch better than me 320i tho :D
www.oldskoolfantasy.co.uk
e30bmlover
Ac Schnitzer prophet
Wed Apr 26, 2006 5:52 pm
if i were you mate i would get the chip out of the ecu as quick as u can, if indeed it is putting more petrol in, it will give u bore wash and f@@@ your engine. get it out......... GET IT OUT! get a zone chip!
dazleeds
old skool raver
old skool raver
Wed Apr 26, 2006 5:56 pm
e30bmlover wrote:if i were you mate i would get the chip out of the ecu as quick as u can, if indeed it is putting more petrol in, it will give u bore wash and f@@@ your engine. get it out......... GET IT OUT! get a zone chip!
who? what??
i have a remapped superchip too
but dnt think i could remove as have headwork and cam etc :roll:
e30bmlover
Wed Apr 26, 2006 6:03 pm
oh ic, speak to ant.
TVRTASMIN
Wed Apr 26, 2006 6:14 pm
From memory Superchips are a "one size suits all" chip. The Unichip can be mapped properly.
Try a Zone chip to see if there is any difference, but if you want things to be as spot on as can be with your setup, then a fully mapped chipped setup on your car is the only option.
Maybe your tyres are underinflated (RAC advice) :D
Wed Apr 26, 2006 11:06 pm
No one's mentioned the suction in the fuel tank. This shouldn't be - the vent to atmosphere for the fuel tank is the 3rd fuel line that runs under the car (slightly different colour to the other two - often a sort of flakey brown/orange colour). This pipe ends in a 500mm rubber hose, the open end of which should be tucked into the reinforcing structure for the front left suspension turret.
Sounds like its blocked somewhere.
georob
Wed Apr 26, 2006 11:27 pm
for 30 quid of super unleaded i get 120 miles in my 320i, tried diff injectors, ecu, chip, pump, filters, no leaks, pissin me off :evil:
Wed Apr 26, 2006 11:34 pm
georob wrote:for 30 quid of super unleaded i get 120 miles in my 320i, tried diff injectors, ecu, chip, pump, filters, no leaks, pissin me off :evil:
You'll get a few more miles for your money if you put in 95 unleaded, which is more than adequate for a 320.
We keep telling you lot that 320s have a drink problem, but you should be getting better than this.
Stoney_god
Fri Apr 28, 2006 8:14 am
There is nothing wrong with the chip as it what previously in TouringDaddy's motor and I nicked his whole ECU so I guessing that the mixture isn't set up correctly in my car ???
JAMZ
Fri Apr 28, 2006 11:17 am
Stoney, 2things:
Where is Tourindaddy lately,has he moved?
And didnt you have his AFM too which indeed was setup to match his chip so you shouldnt be having a problem..
TBH m8 your getting on for a £1 a litre here now, for 20 quids i would get just over 100 miles if i drive sensible..
