Changing coolant levels?
bri957
Post Tue Apr 18, 2006 10:57 am
Quick question
Why would the coolant level on my 320 rise and fall.
Whenever I check the coolant level it is different, one day it will be on the line, the next 1/2 - 1cm above another it will be 1/2cm below.
Does not overheat, no mayo and no other problems.
Cheers Bri
PaulyV
Post Tue Apr 18, 2006 5:28 pm
Not an expert so please correct me if wrong, however should it not rise and fall somewhat due to certain conditions - temperature etc?
best
Pauly
1990 318i LUX, Alpine White, 80,000 miles, as close to mint as I'll ever get.
Simon
Post Tue Apr 18, 2006 6:03 pm
The level will get higher when the engine gets warmer, and fall as it cools, this is normal..
bri957
Post Tue Apr 18, 2006 9:07 pm
Sorry, wasn't very clear.
This is when I give the engine a once over before using it, so from cold.
Could an air in the system cause these symptoms?
Cheers Bri
bri957
Post Wed Apr 19, 2006 12:14 pm
bttt
johnna
E30Zone Irregular
Post Wed Apr 19, 2006 12:52 pm
air- possibly yes.
Is the car always parked on the level?
When I refill mine, I always place a halfords flexi hose into the filler neck and blow hard. This helps expel some trapped air.
I always like to point up a steep hill to refill and bleed as well. This always seems to help.
You may scoff, but Tommy316i replaced his stat, temp senders, viscous link and all sorts before I bled his cooling system this way. He has not looked back since.
You may have a dodgy thermostat, which could be trapping coolant on the cabin side of the circuit sometimes, leaving air in the engine side, then vice-versa...
Or... your heater controls may not be set at the same setting everytime you check/ bleed the coolant...
bri957
Post Wed Apr 19, 2006 1:17 pm
Thanks John
I will see if bleeding it again sorts this out.
