Interference on the radio
Morat
Post Wed Apr 12, 2006 5:28 pm
My 325 just started interfering with its own radio!
There's an engine speed related ticking/crackle noise which gets quite loud higher up the revs. Is this a common thing or is there a simple fix?
(please!)
Morat
e30-320i
Post Wed Apr 12, 2006 6:16 pm
have you got an amp installed
89 325i touring
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Wed Apr 12, 2006 6:17 pm
i know hardly the same, but my micra did that after i put a permanent live from my battery to the stereo.
miniblob
Post Wed Apr 12, 2006 10:02 pm
Right, i'm no expert but from your description, it sounds like something electrical is breaking down.
Could be something as simple as a dodgy connection somewhere.
Check all your cables (back of the stereo/battery/alternator and earths) and if it all looks ok, fitting a supressor (on the output of the alternator, i think!) should stop it!!
Depends on your sound system, but it's weird if it's just started without any changes being made to the system.
Happens quite a bit when changing standard stereo's for aftermarket stuff - dunno if standard one's have filters/supressors etc built in or what!!
May or may not be the problem but i hope it helps!!
Supressors can be got from most car hi-fi shops!!
327 Touring with bass!!!
Globulator
Post Fri Apr 14, 2006 12:14 am
The radio will adjust to low signal levels automatically, but your interference will remain at the same level.
The means that the effect you are hearing can also be caused by a poor
aerial lead and/or connections. You can diagnose this by the tuner being a bit feeble at pulling in the stations even with the engine off.
Morat
Post Fri Apr 21, 2006 12:34 am
oops, thanks for the replies - I didn't notice them get buried in the rest of the forum. I'll try em all out.
