Hi,
Looking to replace my front control arm bushes but I've seen on an online guide that the bushes need to be pressed into the 'lollipop' with a hydraulic press - has anyone done it another way? Can they be done in a big vice?
Cheers,
James
Front control arm bushes
Do all mine in a big vice. Post 96 E36 M3 bushes are a good upgrade.
Part no. 31 12 9 069 035
bottlecapE30
i use a vise with a cheater bar on the vise arm and a little wd-40 makes it easy
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
jamesc
Are they the solid offset ones?Brianmoooore wrote:Do all mine in a big vice. Post 96 E36 M3 bushes are a good upgrade.
James
No, solid centered ones.jamesc wrote:Are they the solid offset ones?Brianmoooore wrote:Do all mine in a big vice. Post 96 E36 M3 bushes are a good upgrade.
James
delphini
JAMES, i need to do this soon but if you like more info go to www.bimmerdiy.com the whole procedure is outlined there as well as other tips and tricks you might find handy!jamesc wrote:Hi,
Cheers,
James
Brianmoooore wrote:No, solid centered ones.jamesc wrote:Are they the solid offset ones?Brianmoooore wrote:Do all mine in a big vice. Post 96 E36 M3 bushes are a good upgrade.
James
Got some of these ordered today for mine. £45.90 + VAT per pair
Quite expensive compared to standard E36 items at £18 + VAT per pair.
I was planning on using E30 M3 eccentric, but when he said £68 + VAT I nearly fell over!!
Lordschleife
Yeah I was planning on that too, and had a similar reaction!DanThe wrote: I was planning on using E30 M3 eccentric, but when he said £68 + VAT I nearly fell over!!
So I'm going to go for the powerflex m3 eccentric ones from the zone shop when I do them, should be around £41 with postage, and hopefully they'll be a bit easier to fit too
Cheers,
Robin
Robin
