M40 idle
smithy318i
Post Sat Apr 01, 2006 5:11 pm
Can any M40 owner tell me how their car idles at first start.
Mine pulses up and down between stall and 1K,
but with the ICV unpluged it stays at abuut 600 and doesn't surge.
cheers.
Gwynleym10
Post Sat Apr 01, 2006 7:07 pm
In my old SA 316i with the ICV that you sent me, when it was freezing it would idle around 1000rpm, then fall to normal after about 30-40 seconds.
My other one does a pretty similar thing, even though it had a head gasket leak....
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
jonbuoy
Post Sat Apr 01, 2006 7:11 pm
Mine does that, it's had a bad idle for the past month. First of all i changed the blue plug and everything was sweet but after a while it's deteriated and i think my afm is going up the wall. I un-plug the ICV and it run's at about 900 rpm :mad:
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Sat Apr 01, 2006 9:19 pm
mine kinda fluctuates between 500 and 1500 :? m40's not well this winter?
will get round to sorting it when the tourer is up and runnin
Rob_316i
Post Sat Apr 01, 2006 10:33 pm
The M40 engine 316i that I just bought does this - it does exactly the same, goes from 1k to near stall and then back up again.
Took it out for a run and when warm it idles at 750 but when you stop at a junction it nearly stalls before settling at 750.
What will happen if you unplug the ICV - is it okay to run it like that ?
4 seats is 2 too many.
Gwynleym10
Post Sat Apr 01, 2006 10:44 pm
_________________
this is what my SA 316i did before i got another ICV for it.
London 2 Cape Town
Rob_316i
Post Sat Apr 01, 2006 11:25 pm
I checked the ICV though and it did what the Haynes manual said it should.
Gwynleym10
Post Sun Apr 02, 2006 9:56 am
So did mine... but car dramatically improved when i put another one in!
London 2 Cape Town
Rob_316i
Post Sun Apr 02, 2006 4:31 pm
Hmm - okay, im beginning to regret the Haynes purchase.
Fought with the dash for an hour before realising the Haynes instructions on dash removal were for the 5 series.
Might try a new ICV
smithy318i
Post Sun Apr 02, 2006 4:34 pm
Dash removal article... http://www.strictlyeta.net/technical/dashboard.html
I have a spare ICV somewhere. So ill try that one.
Rob_316i
Post Sun Apr 02, 2006 5:58 pm
Thanks for that Smithy.
I managed to do it in the end but i swore a lot! :D
JJ26
Post Sat Apr 08, 2006 12:55 am
My 316i M40 has done this every day for the last 7 months of owning the car. Ive changed the rotor arm, dizzy cap, fuel filter, intake hose (split), Blue injection temp sensor, thermostat, ht leads and cleaned/gapped the plugs. Not specifically for this problem il say. Its made no difference to this problem at all :mad: .
I tried another icv from a breakers and it was exactly the same. ive inspected the AFM for freeplay or stiffness but seems perfect. Kinda leads me to the only thing left to try.... ECU!
Note, i turned the emissions down 2 turns of the screw and this seems to have reduced the problem somewhat. Il stick the CO meter on it sometime see if its safe to turn down more, maybe il get more than 26 mpg out of this rattle box yet ;)
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
