Taking cover off of the ecu?
hammoj28
Took the ecu out the car today. Tried to take the cover off but once i had the retaining clips bent back it still didn't wanna come off. Do I have to undo the hex key things too and the screws? The Zone tach guide reckons that its just the clips but it dont seem that way. Thanks in advance.
24v tech2
Ant
- Retired Team Member
the 175 ECU is of the later/smaller type, you will need to remove the torx head screws around the edges, the ones in the central area hold the PCB in place.
HTH
HTH
Email FTW
hammoj28
Cool. Thanks thats pretty much all i needed to know.
24v tech2
