Is there anything special required in the process of fitting it, or is it as simple as unplugging the old one and fitting in the new one? No idling of the car required for 20 mins while the ECU adjust fuelling or whatever?
Cheers Ant, nice oneant wrote:just fit it, top the coolant back up and job's a good 'un fella
possibly may need to get your idle mixture reset, be worth checking anyways
