should the interior lights come on when opening the boot on a touring?
there is a pin switch, that seems to be ok. is this just for the alarm?
touring boot light.
gareth
cros
3 position switch: always off, on with doors open only or on with boot open only. Problem with one on yours?
When I got mine, one of the switch positions didn't work. Just had to open the light & switch and bend a leaf spring back into position.
Then the light used to come on randomly in the boot position (came on overnight once). That turned out not to be the switch or boot catch, but a bit of missing insulation on the switch wire grounding on the body.
gareth
ah... probably got it set wrongly then...
i'll have a play in the morning!
