Hey guys I’m at a stumbling block trying remove the crankshaft… I can’t get the ally housing off the end to remove the crank because of this but behind the timing pulley…
Any help how to remove greatly appreciate before I start throwing tools at it haha
M20 crank removal help
Acaciastrain360
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Do you have to remove the pulley (with the six holes ) first as it seems to be holding the casing on ?
Acaciastrain360
Thanks for the reply, maybe I didn’t word it properly haha that’s the part I’m struggling with getting off
Acaciastrain360 wrote: ↑Sun Dec 19, 2021 1:52 pmThanks for the reply, maybe I didn’t word it properly haha that’s the part I’m struggling with getting off
Have you a three legged puller or you can cobble up a slide hammer using two bolts ,a piece of strip steel with three holes in .
The outer two bolt to the pulley and the centre one is the one which is attached to something you have to hand which can give it a jolt, if you know what I mean?
Acaciastrain360
I got you! Thanks Mart, ima buy a harmonic puller tomorrow
thanks dude
Hope I`m correctAcaciastrain360 wrote: ↑Sun Dec 19, 2021 2:32 pmI got you! Thanks Mart, ima buy a harmonic puller tomorrowthanks dude
Most times just bolting something too it you can hang off while tapping with a copper hammer is enough
Acaciastrain360
Thanks for the help guys, it’s all off and I’ve started cleaning everything…. Just another question, the main crankshaft seal… can I replace just the seal, or does it only come with the ally housing too? Only because the ally bit is nice and clean that’s all
Thanks!
Thanks!
Yes you buy both seals individually
Acaciastrain360
Sweet thanks dude, it’s the only seal that didn’t come in my seal kit
Make sure you use BMW seals, aftermarket stuff is terrible in comparison
