Maplight Mirror Grub Screw
JungleGus
Post Sat Sep 18, 2021 10:48 am
My maplight mirror grub screw (the one that braces against the windscreen to reduce vibration in the heavier mirro) appears to have gone missing - and looking at ETK it doesn't appear to be a separate piece.
Any ideas where I could source a replacement?
onthames
Post Sat Sep 18, 2021 11:12 am
I have one in mine I'll measure for you, could make one if none are available
JungleGus
Post Sat Sep 18, 2021 12:25 pm
That would be most excellent, thank you!
Post Sat Sep 18, 2021 1:44 pm
If you have no luck then I must be able to lay my hands on some at work.
JungleGus
Post Wed Oct 06, 2021 12:55 pm
It's this part here around the back - more of a hollow plastic "screw"
Wishing I had a workshop to knock something up!
onthames
Post Wed Oct 06, 2021 2:56 pm
Sorry I forgot about this... Turns out mines missing too!
Gert_8
Post Fri Oct 08, 2021 12:49 pm
I had a look at mine and the part you have circled in your pic doesn't actually exist..... Did they revise the design at some point?
ifinallyhaveane30
Post Tue Oct 26, 2021 6:50 am
I would be interested in purchasing one of these screws as mine has cracked mostly all the way through and now fails to do it's job thus rendering the mirror mostly useless at speed. It does however make the car feel like I'm going warp speed.
onthames
Post Tue Oct 26, 2021 10:40 am
Do you have a convertible?
Gert_8
Post Tue Oct 26, 2021 10:45 am
Very good! :clap: :clap: Yes. I have got a convertible. When I install the maplight mirror, I simply replaced the mirror part. I will check to see if I kept hold of the hanging bracket tonight.
