Sticky Steering 1990 320i cab
E30Schneider
Post Sun Jul 18, 2021 2:12 pm
Hi All, my 1990 320i cab suffers from steering that sticks from time to time at low speeds. It kind of groans before then freeing up.
It does have power steering and I have changed the pump and belt so far, but no improvement, the old fluid did have some filings in it.
I guess next is the rack, I am not planning to go purple rack as I want to keep the car BOGO standard.
Anyone else experienced this?
Any input welcome.
1990 320i Cabriolet Chromie Royalblau Metallic
BenHar
Post Sun Jul 18, 2021 10:21 pm
If I was changing the rack I would go for a purple tag while you are at it.
Ben
E30Schneider
Post Sun Jul 25, 2021 8:42 pm
Thanks Ben, I looked into this but decided to keep the car standard.
I am getting a reconditioned pump and rack, hopefully that will cure it!
Post Mon Jul 26, 2021 2:50 pm
Make sure you get a realistic warranty, many of the recon racks fail not long after fitting, either because the system isnt flushed out properly (fit a new reservoir while your there) or because they are re built with cheap sh*te seals
E30Schneider
Post Wed Jul 28, 2021 6:02 pm
Thanks DanThe, I will bear that in mind.
