M20 spark plug leads.
ah
Post Sat Nov 07, 2020 12:28 pm
I’m changing my leads for a set I’ve had for a while. number 6 lead has a round electrical terminal with a wire Coming off of it ,I’m not sure what it does but it looks like I need to pass the new through it, which means one end of the lead needs to be taken off, my question is which end and how.
Lemon98
Post Sat Nov 07, 2020 12:38 pm
One of the videos in this playlist has that exact job in it.
https://www.youtube.com/playlist?list=P ... K_X9nnIrr8
1990 4-door 320i SE
ah
Post Sat Nov 07, 2020 2:45 pm
Nice one, cheers for that.
ah
Post Sat Nov 07, 2020 4:37 pm
Not your fault at all, but I followed the vid and Ended up snapping the lead.I managed to separate the rubber cap from the electrical connector and tryed to twist and pull the cap off and as he shows,it wouldn’t come off for love nor money and ended up pulling the lead out of the connector.
Post Sat Nov 07, 2020 6:55 pm
It's an early type of cam position sensor. Without its signal, the engine has no idea which of each pair of cylinders is starting its firing stroke, and which is starting its inlet stroke, so fires both injectors instead of the appropriate one.
BristolE30
Post Sat Nov 07, 2020 10:13 pm
Likely you will need to get a drill bit similar width of the lead, and by hand, drill out the centre of the sensor hole at the end of the lead. Often the new leads are a bit fatter.
Had to do this exact thing the other week when bought a pack of 6 new leads
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
reggid
Post Tue Nov 17, 2020 8:53 pm
why not just get a decent OEM quality set that have the pickup on it?
E30 325is with M20B31
flybynite
Post Tue Nov 17, 2020 10:56 pm
This
I bought an OEM set of BERU ones from autodoc. probably not the cheapest but did not break the bank OEM quality and have the pickup attached
fixedwheelnut
Post Thu Nov 19, 2020 10:57 pm
All the time I worked for BMW (25 years) E30 plug leads come in kit form, a roll of plug lead, seven distributor cap ends, six plug cap ends, and a coil connecter plus fourteen connecters that you crimp on once the leads are cut to length, the sensor is slid on before fitting the end cap.
reggid
Post Fri Nov 20, 2020 8:00 am
12121720529
these days can buy a quality aftermarket set for $100-$150 complete
BristolE30
Post Sun Nov 22, 2020 12:58 am
I’m looking to get a new set for my 325i. I’ve noticed the lengths of the leads is different depending on the brand. Does this make a difference? I did read once that length is quite important.
BMW E30 316 ‘87
Bristol, UK
paultv
Post Sun Nov 22, 2020 8:44 am
I have the Bosch set fitted - spot on.
part number: 0 986 356 323
this:
https://www.pkwteile.de/bosch/1160980?g ... fkQAvD_BwE
Paul :-)
