Does anyone think this would be good as a vacuum leak detector , dependant on the type of fluid used
https://www.ebay.co.uk/itm/Halloween-Sm ... %3A2334524
Smoke machine
I think it should work but 2000 cu ft / min ?????
Bonymaenjack
Bonymaenjack
Bump , all input gratefully received.
How do you intend to use it ?
Bonymaenjack
From a distance
I've tried the hair dryer method using a piece of lint soaked in baby oil which served both purposes of creating the smoke ( loads of it ) and low pressure blowing it into the aperture of the throttle body but I couldn't control the heat aspect and burnt out the wire element . I have thought of going down the route of building my own via Youtube which is simple enough ,but I came across the smoke machine and just wondered for the price it wouldn't be so heath robinson in design and everything's in place to create the smoke , I just need to find a way of pressuring the output .
BristolE30
I built one and works amazing with a bike pump lol
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
