Just serviced the TPS it was full of oil and dirt, i cannot find any information on testing and resetting the correct position. Any information i have found on the Zone and Bentley refer to the 3 pin type mine is a 6 pin round plug. I have so far set it so the micro switch clicks when the throttle is nearly closed does any one have any information on the correct setup, the car is a 1985 325i
TPS
arrisbmw
that's strange . thought they were all the 3 pin type. what engine managemnet sys have you got then ? L - jetronic
PG325
6 pin TPS is for an auto I believe.
arrisbmw
i got auto and its 3 pin. tps nothing to do with auto .
arrisbmw
can you post a photo of it and its location. might be able to help
BenHar
The six pin is for the switchable auto, I believe.
Ben
Ben
