ODOMETER not working HELP
mm1067
Post Sat May 25, 2019 11:28 pm
hi,
need some help if possible.
I have a 1989 bmw e30 320i cab.
my odometer and trip meter doesn't work. everything else on the cluster works tho which i find strange …..
the car was sat for a while before i had it, not sure if that may have something to do with it.
ive read a lot about the gears, plugs, wires etc but was wondering if anyone else has experienced the same problem which could therefore save me some time!
any help appreciated.
thanks
ah
Post Sun May 26, 2019 2:41 pm
Post Sun May 26, 2019 2:44 pm
Sorted.
mm1067
Post Sun May 26, 2019 6:17 pm
Shutthatdoor
Post Sun May 26, 2019 9:21 pm
mm1067 wrote: ↑
You originally posted in the wrong part of the forum ..
Have you done a full search on here for possible solutions ? First thing I'd do as likely someone has previously posted about it.
Check fuses, if that fails remove cluster and check connections to speedo, replace and test
mm1067
Post Sun May 26, 2019 10:42 pm
ahhhhh I seeee.
only been on here a week.
thanks for your help
