rear brake T piece replacement
steve_k
Post Thu Jan 24, 2019 12:13 pm
afternoon folks, looking for help/advise.
been asked by a friend if i would replace the front to rear brake line & T piece on his e30,
thing is i haven't done those on an e30 in quite some time.
also i 'll only be able to drop the rear beam a fraction, as i dont have access to a lift or pit.
my question is what would be the best way to go about removing the T piece? had a look at it & the bolt that holds it in place looks to be in there solid, gave it a good soak in plus gas while i was having a look (god that stuff stinks) i don't fancy damaging the bracket it's mounted on.
any ideas on the best way to remove it without damaging anything?
Post Thu Jan 24, 2019 3:39 pm
Is this the pipe that goes above the tank ?
steve_k
Post Thu Jan 24, 2019 4:01 pm
martauto wrote: ↑
Yep but I'll be re routing it up the side by using braided steel as the main fr/rr pipe will be braided steel as well.
Just trying to work out how to get that T piece free.
steve_k
Post Sat Jan 26, 2019 12:07 pm
going to be doing this on monday, so, any advise???
Post Sat Jan 26, 2019 7:26 pm
Bolt holding the tee piece unscrews more easily if all the pipes to it are cut/unscrewed, and you apply an anticlockwise force to the whole tee piece at the same time as loosening the bolt with a spanner.
steve_k
Post Sat Jan 26, 2019 7:54 pm
Brianmoooore wrote: ↑
Thanks Brian πŸ‘ I knew you'd have the answer
Post Sat Jan 26, 2019 9:30 pm
It's the way I normally shift them , but I've never done it with the tank in situ. I like to drop the tank and rear subframe out, and refurb the entire lower rear end in one hit.
steve_k
Post Sun Jan 27, 2019 8:08 am
he had the tank & subframe refurbed last year, but it failed it's mot this year on the rear brake lines & FR/RR brake line.
