Hi All!
Has anyone on here changed over to a larger 25mm master cylinder? If so which one are you using?
Ta!
25mm Brake master cylinder
paultv
I think you'll find the 750i E32 25mm MC is for an ABS system, so it only has front and rear out to the ABS unit which then has 3 outputs, LR front and a common rear output.
Word is you add a T piece to split the fronts on a non ABS set up.
This will give you a firmer pedal - but lower your braking power for the same input "push" - depends how strong your leg is! all because of the reduced mechanical advantage of the original 19mm or 22mm bore
on the stock MC.
Paul
on the stock MC.
Paul
