Handbrake Cable Firmly Stuck In Control Arm
Stevieabz
Post Sat Oct 13, 2018 3:32 pm
As above, I'm having a really hard time removing the handbrake cable from the control arm. I have stripped everything off. All that is left is the inner cable itself and the outer sleeve that is stuck. Also number 3 on the diagram, the support is still there but the bolts are out but it seems to be stuck there. The inner cable has been disconnected from the actual handbrake and I've tried all sorts to pull it off. PB, heat, vice grips, ALL OF MY MIGHT... I'm worried I'm going to pull the car off the jack stand and squash myself soon.
Any tips or ideas will be very appreciated.
Steve.
1987 325i Sport M-Tech 1 - In Absolute Pieces - www.youtube.com/restoreit - For videos on this E30.
1989 325i Touring - Undergoing a much quicker restoration
1985 320i Sedan - Future Project
BMW 1 Series M Coupe - Daily Driver
blazed
Post Sat Oct 13, 2018 4:11 pm
Mine was the same, I think I hammered the cable out with a drill bit and then part number 3 pulls out.
HTH
paultv
Post Sun Oct 14, 2018 7:59 am
I had the same issue, ended up drilling out the feruls at each end, they were so badly rusted in place, thankfully the new cables have plastic ends so no more corrosion once done. You need to exercise a subtle combination of psychology and Extreme Violence to get those mothers out.
Paul :-)
Stevieabz
Post Sun Oct 14, 2018 5:51 pm
Cheers guys.
Extreme Violence won in the end... About an hour of it. :x :D
Post Wed Oct 31, 2018 5:21 pm
Glad you have sorted it all Steve, :mrgreen: :mrgreen:
