E30 5 stud conversion
akalair
Post Thu Aug 23, 2018 9:07 pm
Hi I am wanting to do a 5 stud conversion on my E30s
I am looking to purchase the below from Ebay. The seller says all I need is e36 m3 control arms and the rest is bolt on. Is this right? Any advice much appreciated. Thanks in advance!
https://www.ebay.co.uk/itm/283102355685
akalair
Post Thu Aug 23, 2018 9:08 pm
This is front and rear.
ChrisHC
E30Zone Contributor
Post Thu Aug 23, 2018 11:39 pm
Why go to 5 studs?
Post Fri Aug 24, 2018 1:49 pm
Possibly more wheel choice ?
akalair
Post Fri Aug 24, 2018 1:55 pm
Yeah more wheel choice and possible m3 conversion. What do you guys think...parts in Ebay as any good?
Post Fri Aug 24, 2018 2:46 pm
The parts on e-bay look knackered. You may be ok with the rear conversion, the front is not straight forward as the caster/camber issues raise their head.
Put a wanted add out for these and pm some guys on here like Dan the, Magpie, sweep, brutus to name a few as these guys could tell and sell you all you wish to know.
Or have a look in the "wiki".
jerseytim
Post Fri Aug 24, 2018 10:18 pm
i used these spacers that let you use the 5 stud hub on the e30 leg so the geometry is still ok and i used a compact 318ti beam on the rear
akalair
Post Tue Aug 28, 2018 1:27 pm
Thanks all,
have sent messages to the above. Lets see what comes back :)
