Power steering belt replacement. Broken tensioner teeth.
chewy320
Fri Jun 15, 2018 5:13 pm
Hi all
Power steering was making some horrible squeaking noises and not being sure when it was last done I decided to change the belt as per the wiki.
All went well until I needed to bring the new belt under tension, the toothed 19mm nut just spins.
I thought the nut had just worn over time but on closer inspection the teeth have snapped off the actual tensioner mechanism. The first couple have gone meaning I can’t tighten the belt.
I read elsewhere that you could manually push the steering pump with a pry bar but I’ve tried all angles and can’t seem to get it to move.
Can the asslembly be bought? Any other ideas? It’s been a day and am already fed up of no power steering.
Chris
paultv
Fri Jun 15, 2018 5:24 pm
Yup, you can buy from BMW, ask Cotswold on here,
Paul :-)
chewy320
Fri Jun 15, 2018 5:48 pm
Thanks Paul, just to clarify this is the slider that the bolt sits in with teeth not the toothed nut?
paultv
Fri Jun 15, 2018 6:20 pm
The adjusting bar is 12311719992 and about a fiver, the idler (toothy nut) 12317677914 is also about a fiver as well - you can get all the nuts and washers also - same for the alternator mounts and aircon if you have it.
The part no's I've quoted are for a 1990 325i m20b25 - but you can search all on http://www.realoem.com/
Paul :-)
chewy320
Fri Jun 15, 2018 6:22 pm
Lovely thanks for your help!
Gavt
Sat Jun 16, 2018 10:49 am
Remember to loosen the bolts on the pump to bracket on the engine whilst you tension or the it will strip the teeth again.
