E30 Rear Cabby speakers
aimlessrock
as above, anyone recommend a good set of speakers that i can fit in the rear door cards.
If someone equally has a set for sale Pm me.
TIA
Gary
TIA
Gary
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
Satan
You have a four door cab?
Satan
Joking apart I have Ground Zero speakers in my car as recommended by Ian Pinder ANA Iceman.
aimlessrock
lol- only 2 doors- well spotted.Satan wrote:Joking apart I have Ground Zero speakers in my car as recommended by Ian Pinder ANA Iceman.
Not come across this make-assume they are good?
190 Mercedes (1988)
190 Mercedes (1988)
Satan
You've never heard of Iceman?
When I asked him what speakers should I get he said Ground Zero so I got them.
Satan
aimlessrock
ah...i see why he is called iceman!
don't suppose you can remember the once you purchased buy chance- i.e model number/name etc?
190 Mercedes (1988)
190 Mercedes (1988)
Satan
Can't remember and as I got them a good few years back they have been superseded, I replaced the fronts with a set of speakers, crossovers and tweeters and also did the rears.
Got them from here,
http://www.caraudiodirect.co.uk/speaker ... 1kQAvD_BwE
Got them from here,
aimlessrock
a hat tip to you sir.Satan wrote:Can't remember and as I got them a good few years back they have been superseded, I replaced the fronts with a set of speakers, crossovers and tweeters and also did the rears.
Got them from here,
190 Mercedes (1988)
190 Mercedes (1988)
Satan
Remember though that in a cab the bass won't be great, I also used a switch in the console to power the antenna as if you aren't listening to radio the aerial doesn't need to be up and it stops the whistling noise when the roof is down.
paultv
+1 for the antenna switch -
Paul
Paul
aimlessrock
...not seen this button before- but now want one.
is this oem?
is this oem?
190 Mercedes (1988)
190 Mercedes (1988)
paultv
Nope! Its an old "Hazard" switch with the emblem removed and "Logo" my lad Storm designed for me, printed onto vinyl - hard wearing - been in the car for a couple of years - in - line with the aerial feed - push to raise!
I have a sheet of stickers somewhere in different colors -
Paul
Paul
Kedge
The aerial on my old cab automatically went up and down when you switched between the radio and CD, same with my 318iS. No idea how they were wired though.
Satan
Was it a BMW head unit? Mines an aftermarket one so maybe not that clever ;o))))Kedge wrote:The aerial on my old cab automatically went up and down when you switched between the radio and CD, same with my 318iS. No idea how they were wired though.
aimlessrock
That looks superb- you interested in selling one of those stickers?- pm me.paultv wrote:Nope! Its an old "Hazard" switch with the emblem removed and "Logo" my lad Storm designed for me, printed onto vinyl - hard wearing - been in the car for a couple of years - in - line with the aerial feed - push to raise!
Paul
190 Mercedes (1988)
190 Mercedes (1988)
Kedge
Satan wrote:Was it a BMW head unit? Mines an aftermarket one so maybe not that clever ;o))))Kedge wrote:The aerial on my old cab automatically went up and down when you switched between the radio and CD, same with my 318iS. No idea how they were wired though.
I think they both had Song head units when I bought them, then the iS got a full ICE install using Pioneer kit, but nothing was done to the cars wiring to fit that.
Malky320cab
I have same issue, can you recommend a size that allows the cover to remain flat? Cheers
Satan
Take one old speaker out and measure the depth, its fiddly but you can get the speaker out just through the gap when you remove the cover.Malky320cab wrote:I have same issue, can you recommend a size that allows the cover to remain flat? Cheers
06UZ
i can assure you to custom Premium Rear Speakers.aimlessrock wrote:as above, anyone recommend a good set of speakers that i can fit in the rear door cards.
TIA
Gary
if you interest, check my google drive
https://drive.google.com/drive/folders/ ... sp=sharing
Satan
Its for a Vert.06UZ wrote:i can assure you to custom Premium Rear Speakers.aimlessrock wrote:as above, anyone recommend a good set of speakers that i can fit in the rear door cards.
TIA
Gary
paultv
The problem with the vert is the tiny space for the magnet behind the speaker mount - the blasted cavity is so small.
Paul
Paul
06UZ
paultv wrote:The problem with the vert is the tiny space for the magnet behind the speaker mount - the blasted cavity is so small.
Paul
Satan
Got my Ground Zeros in with no issues.
paultv
But still 4 inch drivers, no?
Paul
Paul
Satan
You talking front or rear, would need to double check.paultv wrote:But still 4 inch drivers, no?
Paul
Satan
paultv
Yes the back ones, I'm sure mine are 10cm and that's all the space there is unless you start chopping your vert to bits!
Paul
Paul
