Dizzy cap removal
j4gz
Post Sun May 13, 2018 7:19 pm
Has anyone replaced their dizzy cap and rotor arm i went to attempt it but it seemed not to come out is there another method that your supposed to do ?
Post Sun May 13, 2018 8:37 pm
Unscrew the bolts holding the cap, and off it comes. Nothing much to stop it. Rotor arm is retained by small cap bolts, which should be assisted by grips on the outside of the head of the bolt as you try to undo them, otherwise the hex. sockets are likely to strip.
j4gz
Post Mon May 14, 2018 4:18 pm
Brianmoooore wrote:Unscrew the bolts holding the cap, and off it comes. Nothing much to stop it. Rotor arm is retained by small cap bolts, which should be assisted by grips on the outside of the head of the bolt as you try to undo them, otherwise the hex. sockets are likely to strip.
Cheers Brian took your advice sorted the Dizzy cap and rotor arm successfully... next thing that FcukD up wsa that i didn't tie the radiator hose up with a cable tie to stop it hitting the fan so now got a split hose coolant everywhere .....
Satan
Post Mon May 14, 2018 5:42 pm
There is a clip that should hold the hose. A lot go AWOL.
Post Mon May 14, 2018 10:49 pm
A cable tie can be used to secure the hose, and if fitted correctly, looks as good as the OE clip.
Feed the tail of the cable tie through the hole in the bracket from the back, loop the tail around the hose, then feed it back through the hole and push it through the head behind the bracket. Pull it gently tight and cut off the excess tail.
Cloggy Saint
Post Mon May 14, 2018 11:05 pm
Brianmoooore wrote:A cable tie can be used to secure the hose, and if fitted correctly, looks as good as the OE clip.
Brian Brian Brian, I expect better from you, cable tie?? :nono: That reeks of bodge.
Satan
Post Tue May 15, 2018 7:38 am
Next it'll be tissue paper and polyfilla......... the slow descent in to bodgeness.
paultv
Post Tue May 15, 2018 8:54 am
I caught my hose just before it was worn right through - wasn't even aware there was supposed to be a retainer -
Paul :-)
steve_k
Post Tue May 15, 2018 9:12 am
i think most e30's will have a cable tie there by now.
Satan
Post Tue May 15, 2018 9:20 am
paultv wrote:I caught my hose just before it was worn right through - wasn't even aware there was supposed to be a retainer -
Paul :-)
Part Number 3,
http://www.realoem.com/bmw/enUS/showpar ... 1531714433
paultv
Post Tue May 15, 2018 10:00 am
Yup, freely available and dirt cheap - no cable tie for me!
Paul :-)
Post Tue May 15, 2018 10:08 am
The problem is that this part isn't really fit for purpose - hence the large number of missing ones, and members who didn't even realise that there should be a clip fitted.
A cable tie, fitted as I describe, just presents as a plain black plastic band around the hose, that isn't immediately identifiable as a cable tie.
BMW use plenty of cable ties in the production of their cars, and I'm sure you could find a suitable one in a nice BMW parts bag from your dealer, if you insist on genuine parts only.
