water in rear cabby passenger footwell
j4gz
Post Mon Apr 02, 2018 11:13 am
i keep getting water in my rear passenger footwell this issue has just recently started. my roof does leak from the front but i dont think it lets as much water in as there is in rear footwell im totally confused where else it could come from ?
Topblag
Post Mon Apr 02, 2018 11:42 am
Have a look at the stitching on the outside and inside of the roof in that area. If the stitching is loose or missing, water seeps through the holes. Waterproofing the roof with any holes won’t stop water. Could equally be coming in from the front and making its way to the back.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Satan
Post Mon Apr 02, 2018 11:50 am
Rear light cluster, damaged boor seal, rear drain holes blocked.
j4gz
Post Mon Apr 02, 2018 12:45 pm
[quote="Satan"]Rear light cluster, damaged boor seal, rear drain holes blocked.[/quote
can you point me in the right direction please of the drain holes so i can have a look at clearing them and also will check the rest of the places you guys have mentioned thank you ...]
paultv
Post Mon Apr 02, 2018 12:52 pm
Drain holes in sill blocked? allows water to fill up in the rear window cavity and flood into the rear foot well - test by pouring water into the hood storage area on the passenger side next to the roof hinge mountings - water should drain and dribble out of the sill drains.
Also the drains in the inner rear window cavity could be blocked - these allow water to pass from that area in to the sill area for drainage. To investigate this, remove rear seat (all) remove side panel ( with speaker ) shine a torch into the space where the window lives when down, see if its full of mud and water at the bottom.
Oh, I found my picture of the drain in the roof storage cavity.
Paul :-)
BenHar
Post Mon Apr 02, 2018 2:21 pm
This is another picture showing the location of the hood compartment drain hole. This is the left side of the compartment looking forward.
If these holes are blocked there will be water under the rear seat and in the rear footwells.
ImageDrain hole by BenHar, on Flickr
There is one on the right hand side of the compartment too.
Hope this helps.
Ben
